How to remove door panel – CDA CW494
Home Forums Public Support Forums Help And Support Dishwasher Help Forum How to remove door panel – CDA CW494
  • #43239
    timotool
    I have a CDA CW494 which needs to be removed from the kitchen. I can’t see how to remove the wooden door panel. I can see there are plastic pieces between the machine and the door panel (2 on each side), but I can’t see whether they need to be moved, and in which direction.
    Any help greatly appreciated!
    timotool
    #276549
    bazza500
    Re: How to remove door panel – CDA CW494
    The screws in line with the plastic bits that you can see have to be removed and then the door will slide off.
    These screws look the same as all the others holding the door panel on.
    #276550
    timotool
    Thanks bazza500!
    Those screws were very well disguised, and didn’t look as though they were going to release the door panel, but you were right – they do.
    Great job – thanks!
