How to remove front cover off Bosch Logixx WTS86516 Tumbler
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum How to remove front cover off Bosch Logixx WTS86516 Tumbler
  • #88264
    Varoshiotis
    Hi All
    I have a Bosch Logixx WTS86516GB Tumble Dryer (Condenser type), and I need to get to the door locking mechanism. I have taken the top cover off, unscrewed the Control panel out of the way, removed the right-hand side panel, removed the screw at the bottom (cover to the fan inlet & condenser block) and I can feel the front cover edging forward but there seems something holding it around the locking (latch).
    Is there a trick to pull the front cover off? Is there a screw that I need to take off from inside the drum? I am stuck – excuse the punt.
    #437525
    Re: How to remove front cover off Bosch Logixx WTS86516 Tumb
    if its the same at the one I did today. remove the latch cover. its clipped on from the rear, easy to unclip with the left side off. then there is a screw underneath it holding the lock
    Varoshiotis
    Thanks Dave, that did it!
