Re: How to remove integral Tecnik dishwasher door
kwatt wrote:IIRC it’s a Bosch in a dress but not entirely sure as there’s little info on it.
Well if it is a Bosch then, using a T20 screwdriver loosen the two screws either side of the outer door (covered with a blanking cap as a rule) Remember, just loosen them and not remove. Then remove two screws on the inner door liner, the first nearest the bottom of the door and the third from the bottom on both sides. All the while keeping tight hold of the outer decor door as that is what you are removing first of all. Once the decor door is safely removed then take the middle screws out of the inner door and then carefully lift the outer door panel clear of the machine.
HTH?
