how to remove panel door from semi-integrated dishwasher?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum how to remove panel door from semi-integrated dishwasher?
  • #24025
    wallofbeans
    can anyone help me figure out how to remove the panel door from my old SMEG semi-integrated dishwasher ready for the arrival of the new one?
    could do with some help ASAP – thanks!
    #200279
    wallofbeans
    Re: how to remove panel door from semi-integrated dishwasher
    anyone?
    it seems to have two plastic clips at the top on the left and right. it looks like they need pushing down so the panel can be pulled away from the unit but no matter how hard i push i cant get it to move!
    can i just break the clips? will new one come with the new machine? or do i need to save these? there must be a knack to it, i just dont know what it is!
    thanks all
    #200280
    Jonah
    if the clips have a hole in each it is for a T plastic tool to insert and then you pull the plastic tool and the clips release the locking pin on the door, you can sometimes insert a screw into the hole instead of the correct tool and that will do the trick.
    hope this helps
    wallofbeans
    thanks for the reply. the problem was two screws that i hadnt spotted.
    now the problem is one of the plastic clips snapped in the process and ill need to replace it. is that going to be an easy part to find?
    #200282
    Hi, Beany – your new appliance will come with a fitting kit and templates to allow you to fit the door to the it. The fittings are not universal and vary widely between the manufacturers.
