How to replace a foamed in thermistor (hoover fridge)
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum How to replace a foamed in thermistor (hoover fridge)
Viewing 1 post (of 1 total)
  • #82759
    alephu5
    Background:
    I have a Hoover HNMF 2805A fridge freezer that is constantly cooling, thus freezing everything in my fridge. I have bought and fitted a new PCB, and tried to completely defrost the appliance, but the problem remains so the temperature sensor must be faulty.
    Having browsed this forum, it seems that I need to cut out a piece of insulation at the back of the fridge, fit the new thermistor and seal it back in with a bit of foam. I just wanted to ask if I have the right idea before I try it.
    Is this how to change a thermistor?:
    – Allow appliance to warm to room temperature.
    – Remove doors and unscrew metal case.
    – Prop coils against a wall (there are two tubes in the bottom right corner and I am worried about breaking these if I allow the coils to move too far from their operating position.)
    – Use a knife to extract thermistor, working in the gap between the coils and main unit.
    – Feed thermistor cable through cable conduit and attach to PCB.
    – Refoam, reassemble.
    Or am I supposed to access the thermistor from the front?
