Re: How to replace Candy CP2711F upper fridge door seal
Quite a few manufacturers show refrigeration door seals as “available” but they can’t be easily fitted, if at all 😕
Lift the inside of the door seal and see if there are any screws under there, if not then it’s moulded in at the factory. In theory they can still be replaced with the use of a sharp knife and much possible malicious damage to the door liner but it’s not recommended to be honest and I won’t even attempt to fit one.
The whole door is the solution normally, part number 97051940 but at £65.87 plus VAT and carriage it may not be viable 🙁
