Re: How to replace dampers on Hotpoint 9536?
Thanks Martin,
Fixed that, basically the previous owner had overloaded it and it jumped off the left shock, both aren’t failed (did the car shock test) so the machine is ok now thanks to you. There was one tiny crack in the baseplate near the right shock but by making a plate and bolting that on saves it from making it worse (not that the machine will be used at capacity as I prefer half to 3/4 loads in these classic machines, that and the fact that I have a wooden floor that springs). I’m so happy with this machine. I just have to clean up and refit everything.
HOWEVER; The pecker and cable must have came off with previous event so how does that fit onto the motor? How is it possible to take out brushes with the motor still fitted too?
James.
