Can anyone tell me how to remove the door hinge on a Ariston FV271 Gb oven door. I have the new hinges but cannot work out how to remove the old ones.
They have a small hinge on the bottom and a curved arm above with a hook on the end. The small hinge on the bottom has a small nick in it which suggests it hooks over something.
Managed to get the hinges off and the new ones on.
Did it by removing the outer door glass to expose the hinge, removed the screws holding the hinge to the door, leavered the hinge away from the door, then squeezed both leavers together which meant I could unhook the lower part from the door.
