We turned of the breakers in the house and when we put the power back on there were no lights visible on the machine. After pushing multiple buttons and unplugging it, all 5 lights came back on, and the machine started, but it was stuck on a cycle running only cold water and just kept repeating.
Normally the 5 program lights are on until you select a program, then only that one is lit until the cycle is over. Now nothing happens when you hit a program button.
The machine was working fine prior to the power being turned off.
