Can anyone help me with how to access the door striker / switch assembly on this m/c. I want to switch the door direction but clearly need to remove this switch from inside the case and move to the other side with the wiring. Quickly pulled the top off it last night and can access 1 side of the m/c but the other side is under the water container tray moulding (which is mounted to the front and read panels of the m/c looking like a major job to remove). Hence cant access it.
M/C is John Lewis model but looks same as Zanussi TCE7227W and/or AEG models…..
Re: How to Reverse the Door on Tumble Dryer JLTDC06???
you need to remove both side panels release the lock and then try and free up the cable and move to the other side it is tight but can be done then just finish moving your bits and pieces about and cable tie the wiring that you have moved. remember safety first power off and unplug.
