Hi I have a Bosch in for a bearing change and the tub is held together with about 6 screws and about 30 plastic wedge clips , is there a better way to undo these clips that prising with a screwdriver as I have broken two already and have not released any :rolls:
To split this tub you need to cut off the clips and then screw it back together. If I remember right when you order a new seal you get the extra screws with it.
