How to swap out Zanussi DA6141 IWMS – vent grill removal?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum How to swap out Zanussi DA6141 IWMS – vent grill removal?
  • #30889
    johnbradshaw
    Hi. Trying to clean out the IWMS on a Zanussi DA6141. There’s a vent between the main cavity and the IWMS with a grill over it – how do I remove the grill so I can remove the IWMS?
    Will get a new unit from shop@ but hopefully this will get it working in the meantime. Unit is currently only doing 3-4 washes at a time before having to remove the inlet pipe (seems to reset a pressure switch).
    Thanks,
    John.
    #228767
    gegsy
    Re: How to swap out Zanussi DA6141 IWMS – vent grill removal
    IIRC it should unscrew anti clockwise 😀
    johnbradshaw
    Indeed it does 🙂
    Needed a bit more force than I’d originally wanted to give. But given your advice I pushed a bit harder and it started to move.
    Thanks!
