How to take the washer lid off?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum How to take the washer lid off?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #10466
    Hi, my kitchen table is a bit short, I have to take my washer lid off before push it inside.
    I got a new Hotpoint WD420 , how to take the lid off? I have taken out 2 screwers on the back, but i still can not take the lid off.
    Please advise. Many thanks.
    #140114
    litlor
    Re: How to take the washer lid off?
    Steve not sure on this model as it is new but some models have 2 screws on the sides towards the front covered by inserts usury tork screws
    #140115
    Thanks litlor .
    I have just taken the lid off, however, it looks ugly.
    Will that be noisy if I take lid off? is the washer performance the same with before?
    I have to survive with the washing machine even it has no lid.
    It was my diy’ers fault, they made my kitchen table 10mm lower. Most of washers are 85cm tall, however, the space underneath my table is only 83cm and it is not adjustable!
    #140116
    It’ll be noisier. Ideally you need some sort of top on to stop little fingers getting in, as well as the ingress of dust and crud.
    Dave Conway may be able to advise if there is a height reduction kit for that model.
    Pebguin45.
    #140117
    Do you have Dave Conway’s email?
    Thanks a lot.
    #140118
    He’ll spot you soon enough……. 😀
    There are height reduction kits available for the WMA cabinet based machines. They will reduce the height from 850mm to 820mm.
    Part number will depend on the colour of your machine.
    What is the letter after WD420 on the rating plate on the door hinge., G, P or T.
    #140120
    It is WD420P
    “P”
    #140121
    The part you require should be a 9080P Height Reduction Kit. Dave Conway should be able to supply, it is not a high use item so I cannot give you any idea as to price at this time on Saturday 😉 . I would strongly advise that you do not use the machine without a top of some kind.
    #140122
    I have found following parts on Hotpointservice.co.uk
    1600283 Laundry Bag 14 x 14 inches £7.56
    1601191 2M Fill Hose – Blue £7.94
    1601192 2M Fill Hose – Red £7.94
    1601975 4M DRAIN HOSE £11.14
    9050X Stacking Kit – Mercury (for Hotpoint WM50s/60s/70s/80s & Gala Washers & WD 50s/60s/70s/80s washer dryers & Creda W100/120 washers onto all Creda and Hotpoint dryers) £18.04
    9050N Stacking Kit – Natural Linen (for Hotpoint WM50s/60s/70s/80s & Gala Washers & WD 50s/60s/70s/80s washer dryers & Creda W100/120 washers onto all Creda and Hotpoint dryers) £18.04
    9050S Stacking Kit – Zircon Silver (for Hotpoint WM50s/60s/70s/80s & Gala Washers & WD 50s/60s/70s/80s washer dryers & Creda W100/120 washers onto all Creda and Hotpoint dryers) £18.05
    9070P Stacking Kit – Polar White £16.39
    9070X Stacking Kit – Mercury (for Hotpoint WMA/WMS/WMT washing machines onto Creda 5kg vented and 6kg condenser and Hotpoint TL/TDL and condenser dryers) £16.39
    9070N Stacking Kit – Natural Linen (for Hotpoint WMA/WMS/WMT washing machines onto Creda 5kg vented and 6kg condenser and Hotpoint TL/TDL and condenser dryers) £16.39
    9070S Stacking Kit – Zircon Silver (for Hotpoint WMA/WMS/WMT washing machines onto Creda 5kg vented and 6kg condenser and Hotpoint TL/TDL and condenser dryers) £16.39
    9080P Hotpoint WMA Height Reduction Kit Prior Aug 03 – Polar £18.05
    9080N Hotpoint WMA Height Reduction Kit Prior Aug 03 – Linen £18.05
    9080S Hotpoint WMA Height Reduction Kit Prior Aug 03 – Zircon Silver £18.05
    9064 Cold Fill Adaptor £3.30
    9080P is £18.05
    By the way, I saw some notes that the “Height reduction kits” were supplied for products produced before 2003, however, I just bought WD420P last week. Please can you confirm 9080P fits my washer?
    If Dave Conway can send me an email with payment Link, I will buy it from Dave Conway as a thankyou to this forum.
    My email is: hongjun@hotmail.co.uk
    #140123
    Looking at the diagrams for the WMA type machines and the one for your WD420 show what appears to be the same cabinet except for a different mains cable/mains filter fitting and some small holes in the lower back to allow the ‘Indesit’ type PCB to be fitted. The top of the cabinet looks identical but it is only an on screen diagram. It would be safer to make certain before ordering, I can find no reference for kits for late machines.
    I will try and find more info for you if I can.
    #140124
    Hi Steve, Dave will pick this up no doubt, but you can mail him on spares@ukwhitegoods.co.uk if you like.
    Is the “Height Reduction Kit” a lid or 4 feet?
    How it looks like?
    #140126
    It varies from model to model, it can be either or a combination of both.
    #140127
    Just spoken to an old friend (still at hotpoint), in a word he is not sure if 9080P will fit post 2003 machines. He has no other info than is on the web site.
    At under £20 for the kit I would think it a reasonable risk to take, far better than using it without the top on. Please make sure the plug is pulled before attempting to fit.
