Howden hja 8630 dispenser fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Howden hja 8630 dispenser fault
  • #82039
    rogerjohngibson
    The detergent dispenser door in my HJA 8630 will not stay closed when the power is on.
    It does not matter if the door is open or a wash cycle has been run the door will not stay closed .
    the only way to get the door to closed is to swith the power off from the 13 amp socket outlet or the on/off switch in the door
    #418525
    Re: Howden hja 8630 dispenser fault
    Probably just a faulty dispenser but, you’d need to check that it’s not getting powered inadvertently by the control module which, given the description, does sound feasible.
    The detergent drawer is here: http://shop.ukwhitegoods.co.uk/17190001 … -dispenser
    It should stay closed until the solenoid in it is powered up, at which point it pops open.
    The control module is here: http://shop.ukwhitegoods.co.uk/18994506 … ontrol-pcb
    They are known to go occasionally but I’ve not heard of one do that before so, you’d need to check where the actual issue lies.
    HTH
