howdens fr fr hja6100 e8 fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries howdens fr fr hja6100 e8 fault
  • #73611
    keithwilliams
    hi guys i do not repair frost free appliances, but ive had a call with this fault from a potentially very good future customer.
    any advice at all about this will be appreciated and in particular advice on how to fix it.
    if i get this rumnning properly there’ll be quite a few beers in it for whoever helps me out.
    thanks
    #388153
    Dales-Electronic
    Re: howdens fr fr hja6100 e8 fault
    If its of Beko manufacturer and has an ice-maker its an ice maker sensor fault
    #388154
    keithwilliams
    yes it is a beko
    she did say that icemaker has been playing up
    any clues about part and how easy it is to fit. please
    thanks
    keith
    #388155
    SAMURI
    Beko are normally easy to work on.
    If the fridge is not cooling it will be the fan faulty.
    On top the fridge near the main module is normally a sticker with the fault codes.
    But on this model most of the time the codes do not match the fault.
    This model sometimes shows a fan fault as 8 as it is not cold enough for the ice maker.
    You have to remove the ice maker to replace a fan but this is not difficult .
    The fan is in the freezer compartment and you can check if its working by pressing the door switch in the freezer. Make sure you have the fridge door closed.
    The fan has a short delay 10 to 30 seconds if the compressor is running,
    If it does not run after 60 seconds then the fan will be faulty.
    I have repaired a few of this model and it is nearly always a fan fault.
    I have also had a couple with module faults the appliance is normally no go if the module fails.
    Bob
    #388156
    keithwilliams
    thanks bob
    i will deffo report back when i get access to it. may be a couple of weeks as its a holiday let and im also waiting on her cooker model number to order a stat.
    thanks.
