I have the above washer/dryer. It has recently started having problems where it would trip the fuse.
I have taken the top and the back plate off and there is no sign of any water leakage.
If I put the machine on a quick rinse cycle, the machine will fill up, spin, drain and finish with no problems. If I set it to a 40degC wash or a 29min wash, the drum will rotate once, stop and turn again. This continues for a while with no sign of any water being drawn in. Eventually the fuse will trip. I haven’t tried any other programs.
What could be the problem? Could it be the program dial on the front or the PCB?
