Howdens hja8630 dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Howdens hja8630 dishwasher
  • #92054
    Imc
    My heating element stays on. I noticed after putting it on at bedtime it was still hot in the morning. Currently washing on the short cycle so I can turn it off when finished. I can’t see anything obvious but it knocking at times, possible blockage?
    Any suggestions?
    #450148
    Re: Howdens hja8630 dishwasher
    had one recently with the same fault and it was the heater relay failed on the main control board
    Imc
    Thank you very much that makes sense. I wasn’t sure if there was some kind of float switch that would sense the water had gone and switch the heater off. Think I probably need to get an engineer round. Appreciate the quick response!
    #450150
    try here
    http://www.ukwhitegoods.co.uk/search/fi … e-engineer
    I managed to replace the relay on the board to cure the fault but any engineer would have to check its the relay first
    dave
