Howdens Lamona/Candy? washer intermittent failure to start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Howdens Lamona/Candy? washer intermittent failure to start
  • #53997
    cbr1200xx
    Lamona Integrated Washing Machine 1200rpm. This has a start button (three other control buttons) and two control (Settings) dials.
    Recently it has developed an intermittent fault where it wont start when the program is set and the start button pressed. It fails to engage door lock or start the cycle (normally little red LED’s light to indicate success door lock/start).
    Is this a faulty board (Candy 41040895 or similar?) or faulty door closed switch/sensor? or even something else?
    Any help much appreciated
    Paul
    #317982
    paul161201
    Re: Howdens Lamona/Candy? washer intermittent failure to sta
    TrY the door lock
    #317983
    cbr1200xx
    Thanks for the feed back I examined the door lock as that was one my thoughts, but during the process of trying to find the culprit I discovered that the Start button works for some of the programs but not all.
    Rotary control dial with multiple different functions. NOt sure if ROtary control or main board, more inclined to think rotary control. Will have a look at this in the next day or two
    Thanks again for the feedback
