hp wd440p
  • #56962
    gandh1
    does anyone happen to have the resistance values for the various components of the dryer unit on the wd440’s ?
    i.e
    fan motor
    loop type element
    coil element
    thermal fuse wire
    stat
    cheers 🙂
    Rich
    #329385
    Re: hp wd440p
    Depends how accurate you need?
    Roughly (and there are very few situations in which you’d need accuracy here):
    fan mtr 30 / 150
    elements 30
    fuse 0
    stat 0 (assuming n/c type, otherwise infinity)
    (or 5/50k if ntc type – the important thing is it should change with temp)
    Why do you need this??
    Mike.
    #329386
    gandh1
    Re: hp wd440p
    had a batch of hp wdXXX recently with drying faults due to the recent weather.
    just fed up spending ages on the machines cleaning the numerous levels of fluff etc out of the box, put it all back togther and then only to find out the board or other components are failing thru poor resistance. just pretty much wanna check every component first to make sure they are all within working tolerances in one visit. any that arent or are borderline can get ordered with the obviously faulty componentand if needed i can get them all sorted at the same time too.
    #329387
    Re: hp wd440p
    Ah, maybe you’re talking about insulation resistances?
    That is a whole different area.
    Mike.
