never had the pleasure of stripping one of these down yet, somehow.
cust complaint is a rubbery squeak on slowdown of drum rotation – both on spin and wash, assuming its bearing related even tho there is nothing to suggest it in terms of drum play, have already check tub friction on front gasket, and still does it without gasket fitted or even without belt on pulley (in case motor bearing failure)
so am i right in assuming rear bearing seal failure?
