HP wf440 Unknown bearing set.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries HP wf440 Unknown bearing set.
  • #53946
    megawatt
    Just opened up the tub expecting to see a 30 or 35mm standard bearing set. This bearing kit and spider is neither. Has any one got any info or part number.
    Mike.
    #317832
    Re: HP wf440 Unknown bearing set.
    :con: Any pictures?
    #317833
    johnnyj
    If it is 1400 rpm or under it is normaly 30mm bearings, jj
    #317834
    megawatt
    Definitely not your normal 30mm spider or seal. I will try to post some pictures tomorrow.
    #317835
    has bearing spider got brass ring on it like wm series
    opened a sealed tub once they use spider with brass ring
    megawatt
    I think that may be the same. I tried to get a picture on the post but have run out of time. Looks like another hotpoint bites the dust. Thanks for your replies.
    Mike.
