Hpoint WD61 Condenser
  • #7877
    goosegreen
    Went to my last call tonight and found that the condenser had broken loose. All fixings are missing and the bottom of the condenser had come away from the tank. I have tried to find a part number for the seal that goes between the lower part on the condenser and the tank, but cant identify it on Connections or masterpart. Any help with a part number would be appreciated as I promised to get back on Monday next week
    Regards Goosegreen
    #125607
    Re: Hpoint WD61 Condenser
    Goosegreen,
    I assume you refer to the ‘O Ring’ black neoprene seal that sits on the end of the condenser ducting and attaches to the drum with the 3 screw/plate fixings?
    If that’s what you need then they come in a pack of 5 part no: 9800067
    goosegreen
    Thanks for that Martin, I can now send my order to Electrue and and sit down in front of the telly for the rest of the nignt.
    Regards
    Goosegreen
