Hpt 9934P Mk2
  • #31339
    Door frame p/no required. This is the later, motion sensor one.
    Ta,
    Re: Hpt 9934P Mk2
    Strange as it may seem the later, pecker type interlock/door trim is listed as obsolete, the earlier delay interlock is still available. :rolls:
    If it is a push button release then Qualtex DR36 will fit, if it it is a door handle release then DR23 should suffice.
    Masterpart numbers are HP1707 for the DR23 and HP1708 for the DR36.
    Re: Hpt 9934P Mk2
    Nah, it’s the one with the “big button” handle.
    I’ll let them down gently on Monday.
    Thanks, Jim.
    Re: Hpt 9934P Mk2
    Then the DR23 or HP1707 should do the trick, assuming that by motion sensor you mean the pecker device.
    Re: Hpt 9934P Mk2
    Ah. See what you mean. This was the transition machine – early 95 style door, but coupled to a beaking (sorry – pecker) assembly on the motor – BUT – the door frame was modified for the moving lever opening mechanism.
    Thinking about it, I’ve got a scrapper in the garage – I could fit the entire front panel and “update it” to 9515/25/35 standard.
    Some of these little old ladies are very determined to keep these old clunkers going :rolls: .
