Hpt 9945 Wiring
  • #11820
    pegasusk7
    Anyone help with the motor wiring on this old 9945 washer dryer? Machine has previously been fitted with latest type motor and the wires from the mtr plug have come away. I’ve got a pink, grey and 2 whites to play with, the remaining 2 red/blacks go to the tacho.
    Thanks,
    Phil
    #146831
    Re: Hpt 9945 Wiring
    Wiring differs depending on drum, is it plastic or vitreous enamel?
    Original wiring on plastic drum is… 2 Red/Black
    6 White
    On the vitreous drum it is… motor plug 2 Red/Black.
    1 Red/Brown
    1 Pink
    1 Red
    1 Grey
    Suppressor(choke) 2 Pink
    2 Grey
    2 pin plug 1 Pink/Grey
    1 Violet
    Machine may have had a motor conversion, has the motor plug been butt connected into the original harness, if so I can give you the destination of the wiring from the original colours.
