hpt aqualtis AQM8F pump comes on then goes off Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hpt aqualtis AQM8F pump comes on then goes off This topic has 4 replies, 5 voices, and was last updated 9 years, 2 months ago by mike100. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts January 13, 2017 at 5:03 pm #90340 mike100Participant All progs set ok but wont pump out as pump comes on for a few seconds then stops. Checked pump and no blockages Any help please Mike January 13, 2017 at 7:23 pm #444455 iadomModerator Re: hpt aqualtis AQM8F pump comes on then goes off Have you tried another pump just in case the pump overload is over sensitive. Failing that then it points to pcb failure.:( January 13, 2017 at 7:26 pm #444456 kaibartModerator Re: hpt aqualtis AQM8F pump comes on then goes off Or the dryer ntc do cause odd faults the aqualtis modules rarely fail January 17, 2017 at 1:50 pm #444457 AlanjParticipant Re: hpt aqualtis AQM8F pump comes on then goes off Did you try the Hotpoint pump/pressure switch reset procedure? hotpoint-indesit-pressure-switch-reset-t69601.html January 17, 2017 at 2:40 pm #444458 rolfParticipant Re: hpt aqualtis AQM8F pump comes on then goes off I had exactly the same problem. Broken wire on ntc caused mine, hidden behind the cable tie. Only found it after changing pcb. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
