hpt bwd129 dryer water valve on all time
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hpt bwd129 dryer water valve on all time
  • #65603
    LittleMan
    Hi Called on this machine today if you start machine the dryer valve comes on all the time untill the door opens then it turns off.Can anyone help.Les
    #361243
    Re: hpt bwd129 dryer water valve on all time
    If all the wiring checks out then its got to be the main PCB. EMW time perhaps.
    #361244
    LittleMan
    Thanks for that found out price from hotpoint £86 +p/p and vat comes unprogramed will need smart card reader and card another £89 whats that all about. Les
    #361245
    DDDave
    Try EMW for a reconditioned board.
    #361246
    EMW will test the board and if no fault is found make a small charge or replace/repair it for around much less than a new board , programmed or otherwise,if it is faulty.
    They will also give you a decent guarantee on the board, you will get no guarantee whatsoever on a new one. 8)
    http://www.emwelec.co.uk/
