Year old dryer, condensor and float were blocked, over heat stat tripped. Replaced but customer used once and overheat tripped again. Airflow good, it is reversing and cap is fine, will replacing ntc and thermostats usually solve this. Anyone come across anything else.
No fault codes but the m/c is totally dead once stat has tripped
