HPT CTD80P
  • #28784
    cornflakes
    hi visited this appliance TOC.S open circuit. Have posted previous info last month
    just fitted replacement set, although did not fit white TOC just pair above heater( as 1 of there was open circuit)
    unit programmes and runs for 2 mins
    error fault F13 comes up.
    can’t seem to find fault codes on lists posted
    any help welcome
    Graham
    #220110
    deltra
    Re: HPT CTD80P
    hi graham, f13 rear ntc open or short circuit.
    #220111
    Re: HPT CTD80P
    Error codes for this are on page 4 of known error codes thread. Make sure the condensor is clear, two different stat kits depending on date code, different NTC’s used. You should always replace all three if any one of them fails.
    Johnnyboy
    Re: HPT CTD80P
    I have one E13 rear NTC fault, only problem is I cant find a rear NTC!!!!! the heater has two stats the white spot kit was replaced as the y were o/c I shorted out the front ntc and got that up as an error just to check, but cant find a rear NTC on a 2 stat heater, Am I blind (or stupid)? Cheers
    #220113
    burns
    Re: HPT CTD80P
    as per pre mail, I visited one of these it had just a white spot cut out and the thermistor. The thermistor in appearence looked identical to the cycling stat.
    I have spoken to others who have experienced the same having fitted the two out of the three parts to the kit.
    Is it possible you changed the two and retained the new thermistor.
    i.e thats the cutout wspot and cycling stat in place of the thermistor due to appearence?
    If this is the case it will not perform and shows a fault after a few minutes.
    If this is correct replace the thermistor with the fitted stat and all should be well???
    I know what I mean hope it makes sense :rolls:
    Does sound like you have substituted the original NTC with a cycling stat.
    Later versions have all three fitted L-R w/spot toc – cycling stat – NTC
