HPT CTD85 Drum support wheel
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries HPT CTD85 Drum support wheel
  • #33172
    andy2
    Hi – The drum support wheel for these is no longer available according to CDSL, superceded by pn: 1703273. This is a front and rear bearing and belt kit.
    My question is do they already have the bearing pads fitted in these as well as the support wheels ie. if the wheels are knacked can you just remove them and let the pads take the weight?
    Andy 😀
    #237672
    Re: HPT CTD85 Drum support wheel
    Thats exactly what you should do , throw the stupid, noisy wheels away, replace the felt strips and the bearing pads that are in the kit. The kit usually has full instructions with it.
    hotpnt
    no, they used to run on the wheels for support, which gave the horrible rumbling noise, some were produced with a few pads and wheels but they have usually worn out, they are the same as any of the other hotpoint front pads, so you can fit some of those if it saves you having to order a kit, just check the belt at the same time
    #237674
    hotpnt
    damn jim, your quick tonight, cant you find anything good on TV either? or just trying to get out of the xmas wrapping like me 😆 😆
    #237675
    I wish, I took today off, I do it every year at this time, down to the Trafford Centre and do the Christmas shopping all in one blast. Its the hardest days work of the year.
    I’m actually setting up a new laptop so I am flitting between PC’s ATM.
    hotpnt
    so you went xmas shopping and came home with a laptop?, nice, got a new laptop few months back, well worth getting one of those data transfer cables, was pulling out what hair i have left when i tried without one
    #237677
    andy2
    Thanks gentlemen for your swift replies. From what you say it is advisable to suppose that no bearings are fitted and to fit the complete kit, so that will i do, i will to be sure.
    Thanks a million have a great holiday
    Andy 😀 😀
    #237678
    The laptops a present for someone else, just clearing all the crap such as AOL, Norton AV, and piles of other rubbish that HP have pre installed, setting up the wireless connection etc.
    hotpnt
    ah right, good luck then, never understood norton av, seems to grind everything to a snails pace
    #237680
    andy2
    I have done a couple of these since my post – not too bad! Is there anywhere that sells non GEN bearings for these as the HPT ones are extortionate (rather than buying the kit). The old non gen will not do as the plastic housing is much thicker than the metal was.
    Andy 😀
    #237681
    None that I know of, the gen ones are graphite, hence the cost. As the complete kit is £20.50 + vat and four pads would cost £13.20 + vat list price it makes sense to order the kit and change the rear bearing plus all the seals that come with it TBH.
    andy2
    Pity really as fitting the bearing pads is very quick compared to a belt change and the metal rear bearings don’t seem to wear much.
    I can’t see the point of graphite bearings even though it is self lubricating it is softer than plastic so i can’t see it lasting any longer.
    Anyway thanks for the info Jim – much appreciated.
    Andy 😀
    PS – Seals ??
    #237683
    It usually comes with the rear foam seal and the felt front seal.
