This dishwasher fills for about 20 to 25 seconds then the drain pump kicks in with 5 lights flashing, these are wash, drying, end light, salt and rinse aid. Continues to drain with lights flashing until you turn it off, will even continue to pump with the door open. Once reset it will do the same again. Checked there is no water in the base. Insulation test ok as well.
