hpt d/washer
  • #44651
    dopper
    bfi620 dishwasher fitted a new heater. the hose to left will not stop dripping hose looks ok got the jub clip as tight as i can get i was not sure if it was the heater leaking or the hose strange cant c y it wont stop. anyone had this>?
    #281782
    Re: hpt d/washer
    Didn’t you use Debor?
    Mike.
    #281783
    johnnyj
    Re: hpt d/washer
    Cannot remember the part n/o but the the jubilee clip on the 1604035 sump kit was the one Hotpoint used to fit the heaters never had one leak and i’ve done loads of them, no need for any glue cheers JJ
    #281784
    kiddo66
    Re: hpt d/washer
    There is a litle tab on this hose which has a habit of getting bent in on itself when you fit the new heaters.Take the heater out and check to see it isn,t trapped.
