Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hpt Motor Conversion Problem.
- This topic has 19 replies, 10 voices, and was last updated 19 years ago by
happycack.
March 29, 2007 at 10:00 am #26218
happycack
ParticipantDoes a Hotpoint motor conversion work on the old 95 series? I have done two in as many months and both customers complain of excessive shaking as the machine enters spin mode. Almost as if it accelerates into the spin too rapidly. Even put new suspension legs on one of them, helped but didn’t cure it. Anyone else had this and if so did you cure it?
March 29, 2007 at 2:34 pm #209227lone
ParticipantRe: Hpt Motor Conversion Problem.
Just a though…. you didnt put a digital motor on?
i think hpt 1604810 should be used.March 29, 2007 at 4:05 pm #209228hotpnt
plus the fhp motor is alot longer & can hit the side mounted pressure switch very easily
March 29, 2007 at 4:27 pm #209229johnnyj
The old analogue motor you have to make sure the wash speed is set up correctlty also as it will cause excessive noise and banging about, there was a strobe disc to set it, i used to just count the amount of times each paddle struck the water you adjust screw on back of tacho, i set speed to approx 33 strikes which worked out at about 56 rpm.
March 29, 2007 at 4:30 pm #209230JOHN CLARKE
For 95 series (timer controled as against control unit type) use 1604810 or 1604812.
March 29, 2007 at 6:16 pm #209231timdowning
(digital) motor 1604822 dosen’t work on 95 series machines. The motor distributes to fast.
March 29, 2007 at 6:27 pm #209232happycack
The original motor isn’t available anymore. The wiring diagram shows how to convert the ‘two times four’ block to the ‘straight eight’. Yes distribution IS too fast but is there anything I can do about it failing short of taking the motor back off and giving them their money back?
March 29, 2007 at 6:38 pm #209233timdowning
Homespare have got stock of 1604812.
Other than that i think money back 😥
March 29, 2007 at 6:44 pm #209234suedehead1
with these older hotpoints i always just change the armature qualtex still supply them ARM 20 unless there is anything else wrong with the motor.
March 29, 2007 at 6:47 pm #209235happycack
Had a feeling it was edging that way. Shouldn’t take on a motor change unless at least WM range. Shame though, who can say that the new Hotpoints are anyway better than the older ones??
March 29, 2007 at 6:51 pm #209236happycack
Sorry suedehead1, not an armature fault, definitely windings. Probably T.O.C.
March 29, 2007 at 6:53 pm #209237suedehead1
i just bypass the toc they normally only go if the armature needs changed.
i am sure someone will say this is not the thing to do but i have never had any problem.
i used to keep the old tocs out of old motors they just pull out.March 29, 2007 at 6:57 pm #209238Penguin45
Q/tex TOC17, Hpt 1601600.
Pretty risky practice to bypass any safety device………..
March 29, 2007 at 6:59 pm #209239happycack
Don’t go there mate. I once mentioned bypassing a door lock once and I still get hate mail. !!!
March 29, 2007 at 7:02 pm #209240suedehead1
you could get away with these kind of things in the good old days.
i remember going to a hoover twin tub which would spin with the lid open someone had bypassed the switch.
i would never bypass a door lock now but did in the past untill i went back with a new one. -
