hpt Special Bolt
Home Forums General Trade Forum hpt Special Bolt
  • #44385
    garn
    Hi There Garn Hear.
    Just Had Delivery Of A New Bolt For My Hotpoint Bearing Removal Set.
    There Is A Note Saying About An Update To The New Bolt As Follows.
    The Enclosed Bolt IS Being Sent To You To Replace Existing Bolt In your Bearing Removal Kit.
    A Small Number Of Bolts Have Failed Due To The Weld On The Bolt Head Breaking.
    Please Replace The Bolt Immediately On receipt And Return the Old Part Clearly Marked As Scrap.
    ❓ Does This Mean IM Going To Get My £ Back Or Evan A Credit 😕 Its Increased In £ To 😯
    #280811
    suedehead1
    Re: hpt Special Bolt
    what was the part number for that bolt i am in need of one as well.
    #280812
    garn
    Part Number GDA5600138
    The New Bolt Will Be Stamped G ON The Head.
    I Recommend To Keep An Eye On The Wear On The Thread OF The New One. After Several Uses You Can Tell The Wear On The Last 10mm At The Bolt Head ➡ Stretch : Use Buckets OF Grease 😉
    #280813
    Hi Garn,
    If you ordered this as a replacement part due to wear, I doubt that you will have any come-back.
    garn wrote:Part Number GDA5600138
    The best way to look after these bolts is to try not to force them.
    Tap the bearings in, grease the threaded shaft well and start to tighten. If you start to get serious resistance then take the fitting tool out and have a close look at the bearings, you should be able to see if they are not lining up correctly, just tap the edge of the bearing with your trusty knockometer to tap it into line and try again.
    I have a threaded shaft that has done hundreds of bearing jobs and it still runs a smooth as new.
    garn
    Your Correct Chris.
    I Have Stretched A new Model GBolt. There Will Be No Refund ON That One 🙁
    I Have Had Several Up dates On These Pullers Over The Years
    I Have Two Earlier Bolts 1 Which is About 6 Years Old head Has Twisted Off 😥 As Soon as i Bought A New one Not G Update I Run A 110 amp weld Round The Head Of The Bolt Its Still Going Good To Day.
    Mine Has No Chance. ❗
    I was Just Wondering Whether You Can Get A Credit £.
    I Bought The G update 2 Years Ago This Bolt takes A Good Hammering On The WMA Appliance Range .
    #280816
    garn
    Your Correct Jim.
    I always Degrease the Bolt And Keep It Clean
    IT Will Last For Years. A Soft Copper Hammer Can Be Useful
    these days I Prefer To Put A New rear Half On It Can be Hard Work These Days
    Paul
    #280817
    This afternoon I will be fitting my fifth WMA rear half this week, the old back is complaining a bit. 🙂
    cornwell40
    Still got my original bearing puller from 1990. A little looser than it was but works a treat still. Not used as much as it was though 😥
    TC
