hpt td stats
  • #16563
    abbots
    hi,
    can anyone tell me part no for thermal cut out kit on a CTD00 31349
    thanks.
    jk
    #170480
    Dave_Conway
    Re: hpt td stats
    According to Partfinder you can only buy the heater but the cut-out kit is part number 1703200 😉
    #170481
    abbots
    Re: hpt td stats
    cheers,
    they seem to be out of stock at connect.Have you got the part no. of the heater assemble?
    john
    #170482
    Dave_Conway
    Re: hpt td stats
    Yep, it’s 1703005
    #170483
    abbots
    Re: hpt td stats
    cheers mate
    #170484
    keithwilliams
    Re: hpt td stats
    if the cut-out hasn’t got a hole in the back, then drill a tiny hole in the one thats on and reset it with a pin. i’ve done that loads of times when i’ve been caught short and not wanted to go back. mind be very careful when drilling or you’ll go right through.
    #170485
    bobokines
    Re: hpt td stats
    There are several threads of similar theme to this one.
    It must be stressed that it is not safe to reset these stats. In my opinion they should not be known as stats but should be referred to as a Thermal Fuse.
    They trip for a reason and simply resetting them is not solving the original problem.
    Pushing them from inside with a pin can send them wildly out of calibration. So much so they may not provide any protection in the future!
    Bob
    #170486
    keithwilliams
    Re: hpt td stats
    sorry perhaps i should have pointed out that the cause is eliminated first. ie blocked condenser etc. and i did say reset it gently with a pin not a sledge hammer. never ever had a call back, and lets be honest its no different to the ones that already have a hole in, or the red one on a crosslee tumbler, they just blocked it up so we’d all buy new ones. finally the latest hotpoint condenser dryer that i’ve been to had a resettable stat in it.
    #170487
    bobokines
    Re: hpt td stats
    Could it be that you ‘have never had a call back’ because it doesn’t work any more? If it has gone out of calibration then it’s possible that it is no longer giving the protection that it should.
    Also, the stats come in pairs, for the one shot to have tripped, it implies that the other stat is stuck in short circuit, or that it has gone out of calibration resetting the one shot obviously means that the other one is not being replaced
    Sorry, I might be being over-cautious but I will always replace a trip that has failed unless it is designed to be reset. The stats with a pin hole in the back are not, in my opinion, designed to be reset.
    Bob
    #170488
    johnnyj
    Re: hpt td stats
    The heater kit is 1703248 comes with stats fitted cheers jj
    #170489
    Re: hpt td stats
    bobokines wrote:resetting the one shot obviously means that the other one is not being replaced
    Bob
    Not necessarily. I had a problem a while back where they kept sending kits with 2 stats in instead of one stat and one t.o.c. These were genuine HPT kits.
    Also there may be other sources for a new thermostat (RS for example who will send even one small item carriage free – saves making up a big order).
    Mike.
    #170490
    funkyboogy
    Re: hpt td stats
    if you get persistant probs with the one shot stat, try replacing the capacitor as well,reason behind this ..dryer works fine for 20 mins or so, but then develops motor movement probs due to faulty capacitor..
    hope this helps
    cheers f/b
    #170491
    Turbo
    Re: hpt td stats
    Have to agree with Bob on this one thermostats should never be reset unless there is a obvious reset button built in. Its just not worth the risk of a fire.
