HPT TL61 shaft kit, circlip etc
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts HPT TL61 shaft kit, circlip etc
  • #30303
    Seamy
    Connect show a kit:- Order Code: 5031685290641
    i also need a cirlip
    Does anyone know the part number for the little circlip that goes on shaft.
    I’ve to do a job on a machine that has broken shaft off circlip is broken, shaft is sheared through, square bearing is busted & square housing is damaged too. so much for stretch belts.
    #226708
    Re: HPT TL61 shaft kit, circlip etc
    1701662 = Shaft repair kit
    1701527 = Circlip
    1703014 = Square bronze bearing
    #226709
    That shaft repair kit includes the bronze bearing and the pin which is now used to secure the shaft. Used to include new rear bracket & two pop rivets as well.
    Seamy
    Cheers guys
