HPT VTD00P
  • #20052
    pegasusk7
    Anyone know the answer to this?!!
    I am in need of a PCB Relay for Hotpoint TD model no.VTD00, serial no. 410190639. The original module is approx 5cm square, 3 tags numbered 1 to 3 from left to right (1.Brown/White 2.Blue 3.Pink/White). The new module supplied by Electrue part no. 1703642 is 9cmx5cm which won’t physically fit without removing a mounting post on the fascia and has 3 tags numbered 1 to 3 from right to left. If connected as per the original wiring it blows the plug fuse.
    Any help appreciated!
    Phil
    #185618
    johnnyj
    Re: HPT VTD00P
    1702278
    #185619
    pegasusk7
    Re: HPT VTD00P
    1702278?
    Err, that’s a cooling impellor according to Connections?
    Phil
    #185620
    Goatboy
    Re: HPT VTD00P
    Is it connect number…
    5031687544940
    #185621
    johnnyj
    Re: HPT VTD00P
    Sorry its 1702778 my fault.
    #185622
    pegasusk7
    Re: HPT VTD00P
    Yep, that’s the one they’ve supplied, 3 times in total now!
    Phil
    #185623
    pegasusk7
    Re: HPT VTD00P
    1702778 (correct picture as per original) is superceded by 1703642 according to electrue. Could it be that what is being sent is correct but needs to be wired differently? Does anyone have a number for Hotpoint technical, the number I have is no longer recognised?
    Thanks for replies so far!
    Phil
    #185624
    Re: HPT VTD00P
    pegasusk7 wrote:Does anyone have a number for Hotpoint technical
    Hotpoint Technical?….you should be so lucky…try this instead :bang:
    #185625
    Re: HPT VTD00P
    Very strange, still only 1702778 listed on Partfinder, 1703642 not even recognised. It is very unusual for Hotpoint superceded spares not to come with full fitting instructions.
    Looks like you will need the assistance of some kind person with Emit 😉
    #185626
    Alanj
    Re: HPT VTD00P
    Hi Phil,
    part still listed with Masterpart 1702778 price £13.79.
    Alan
    #185627
    pegasusk7
    Re: HPT VTD00P
    Thanks, guys.
    Have spoken with Hotpoint who suggest part no. 1703656 but Connections doesn’t recognise it. Does this no. appear anywhere else?
    Fed up Phil
    #185628
    Dave_Conway
    Re: HPT VTD00P
    Partfinder (Hotpint’s own spares disk) doesn’t recognise 1703642 or 1703656 so they may have done some very recent modifications ? 😕
    Order one from Hotpoint directly perhaps ?
    #185629
    pegasusk7
    Re: HPT VTD00P
    Just for the record part no. 1703656 has proved to be correct as supplied directly from Hotpoint.
    Phil
