Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hpt WD420 heater box modification 39 date code
- This topic has 11 replies, 5 voices, and was last updated 19 years, 2 months ago by
Electricmalc.
February 5, 2007 at 6:38 pm #24785
Electricmalc
ParticipantHave the above machine with a blown toc in the heater box.
Did a search on whiitegoods, before I attended the job, which came up with a modified heater box, part no 1605230. The posting was in March 2006.If I enter the part no on connect it comes up with Obsolete. No alternative is listed.
Can anyone give me any info on the current status re the heater box modification please.
The link to the posting in March is
http://www.ukwhitegoods.co.uk/modules.p … ight=wd420
Malc
February 5, 2007 at 7:08 pm #203301iadom
ModeratorRe: Hpt WD420 heater box modification 39 date code
The latest version of Partfinder still shows the info pointing towards a 1605230 as the correct part but as you say it is NLA. However looking up the heater assy for the WD860 which is the same, informs you that that the heater has been changed back to the spiral type and the complete assy is NLA. They have also gone back to the thermal fuse in the sheath. The four way valve & flushing kit has been re introduced together with a metal fan blade to replace the plastic one.
I guess you will have to check it out and order the individual parts as required.
PS. I have amended that original thread.
February 5, 2007 at 7:50 pm #203302Electricmalc
ParticipantRe: Hpt WD420 heater box modification 39 date code
Thanks Jim 😀
All noted, will find out how much that will cost.
Cheers
MalcFebruary 5, 2007 at 8:00 pm #203303helo_75
nope, it is available. i fitted one the other day, ill try and fish out the new part number
February 5, 2007 at 8:13 pm #203304Fairdeal
Is the thermal cut out in wire with sheath not much easier than that of the sensor type?
I have seen that the hotpoint in their newer W/D have changed to the original sheath one themselves.
I may be wrong but I have found them really difficult to put them in.
Is it only me or someone else had same problem
Regards
February 6, 2007 at 6:35 pm #203305helo_75
and the part number is 1605710
it comes complete with the new coiled element and sheathed thermal fuse
February 6, 2007 at 6:54 pm #203306Electricmalc
Thanks Helo 75
Malc
February 6, 2007 at 7:08 pm #203307iadom
Nice one. Comes up as No Items on Partfinder, also not recognised at Masterpart yet but Qualtex/Spareslink does list that part as a special order item. 8)
I have added that to original thread.Jim.
February 6, 2007 at 9:37 pm #203308mutley
Be careful however as this part is not a direct replacement for any machines prior to date code 54 as they will require an update to the eprom files
Nice when things are staight forward 😕 😕
February 6, 2007 at 10:47 pm #203309iadom
I nearly made it my New Years resolution to stop soiling my hands with Indesit rubbish, I am becoming sorely tempted to activate said resolution. 👿
February 7, 2007 at 10:46 pm #203310helo_75
lol, ud make no money….
yup, on later models, the eproms diff, so thats gonna be a prob.. however, its down to the termistor i believe, and that can be swapped over
mybe, just maybe, if they designed summink that actually worked, it would be better
when was the last time ne 1 changed a bosch washer dryer fan motor?
all the need do is make a fan motor with a split pin and a proper nut on it instead of that stupid collet idea and itll be fine, but oh no
i wish i got paid the money the ppl who think these things up
helo
February 7, 2007 at 10:55 pm #203311iadom
helo_75 wrote:lol, ud make no money….
I managed to make a butty, for over 20 years without touching the garbage that the Indecent Company turns out. It is only due to the very large number of longstanding customers that sadly still buy Hotpoint & Hoover machines because the old one lasted 15 to 20 years that I have had to prostitute myself repairing this sh**e. However the worm is turning 😉Jim.
