hpt wd440
  • #28224
    dopper
    on off switch flashing and dryer high heat flashing can’t see it on codes
    paul
    #217416
    Re: hpt wd440
    Its there if you look carefully, page 4, always get the neon by number from the top down,
    Neon 1 = F08, or in other words the dreaded 8 flash jobby, heater relay not energised, along with all the other possiblities that cause this fault code. 😥
