gandh1 wrote:
iadom wrote:
Codes for most Hotpoint WF & WD machines without digital display.
f05 lights 2&4, pressure sw stuck on full
further to this, in case anyone unfamiliar with a wd440 is stuck, got this on because it wasnt draining and door wasnt releasing – feared the worst as the pump wouldnt make a sound at all, anyway perservered, turned out it was a large tag off a zip jamming the pump. oddly enough, when gravity-drained it cleared the error display but didnt flash one up for a pump failure… when tending drain next
Moved from Error Codes.
Please post only Error Codes in the thread – if you wish to comment, do so in Trade Technical and link.
Chris,
Moderator.
