Hpt WD860G Fan motor
  • #42696
    RocketMan
    Serial 48142631.
    Could someone confirm that 1604800 is the correct part number for the fan motor. (dead bearings) Also does this need the fan collet (1604801) to fit the fan as the motor on there at present looks like it is held by a nut.
    I’m sure it was cold fill only and has flat type dryer element.
    Steve
    #274501
    Re: Hpt WD860G Fan motor
    Is the fan plastic, if so fit a new metal one, C00080658.
    Motor number is correct for that serial number.
    RocketMan
    Thanks Jim. Yep plastic fan as well quoted for all parts. Help much appreciated. Steve
