Hpt WDF740 f01 error
  • #61323
    roy1
    The machine has a mk 8 board & a brush motor,spins ok but if you
    select 40 cotton wash it runs from 126 min to 122 mins then goes into
    error F01.
    Tested insulation on heaters, motor, dryer parts ect, valves test ok tested with heater disconected and spare Nct still error after 4 mins, strange fault.
    #345682
    helo_75
    f01 is a motor triac error
    if the motor and wiring in plug check out ok, its the main pcb
    #345683
    roy1
    Re: Hpt WDF740 f01 error
    Thanks for the help, that was my next step its just odd that it spins ok
    and will wash for 4 mins before error.
    The only thing i could think of was that the error was at the change from
    normal wash to gentle action for heating.
    #345684
    roy1
    Fitted board from EMW, been working fine thanks for your help.
    Roy
