HPT WF 860 error/test
  • #28926
    roy1
    Hi, the display was showing test with the machine filling & pumping.
    I cancelled the test mode it then came up FO3 NTC fault,checked
    the thermistor, loom, heater , removed the 3 phase board & cleaned edge
    connectors & pinched the connector blocks.
    still same problem, new board? anyone had this fault
    Thanks Roy. 🙁
    #220681
    timdowning
    Re: HPT WF 860 error/test
    Board fault if heater,wiring,ntc ok.
