Led’s from top to bottom on left 1 2 3 4 flashing along with 5th across (final spin) & On/Off led flashing rapidly when power switched on at wall. Any ideas, i’ve looked at fault code section on here but none the wiser.
Thanks in advance.
Power supply on the PCB – EMW for a replacement. Make sure you have the correct type when ordering though; there is either ICT FT (Mk4) or ICT FCT (Mk8) fitted to this range. The ICT letters are found at the end of the PCB printed in little boxes.
