Hpt. WF541P Inlet Valve Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Hpt. WF541P Inlet Valve This topic has 4 replies, 3 voices, and was last updated 17 years, 1 month ago by Phidom. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts February 14, 2009 at 3:28 pm #43477 PhidomParticipant Machine in garage has suffered frost damage so I need a double solenoid valve. Does it only come complete with dispenser housing? February 14, 2009 at 3:55 pm #277367 helo_75Participant it does… is it just a double valve thts screwed on? February 14, 2009 at 5:52 pm #277368 PhidomParticipant Re: Hpt. WF541P Inlet Valve Yes, an Indesit type setup. Machine is a welded drum type, quite different to my own older WF540G machine. February 14, 2009 at 6:08 pm #277369 timdowningParticipant Re: Hpt. WF541P Inlet Valve I had the same trouble on this version and found that an old indesit valve I had fitted perfectly, all I had to do was individually spade the wires. I think this connect part number is the right fitting: 5031689604116 February 14, 2009 at 7:55 pm #277370 PhidomParticipant Re: Hpt. WF541P Inlet Valve Thanks Tim, the valve you mention has the solenoids on the opposite side so they would come under the soap drawer housing but I don’t think that would be a problem. I will check if I’ve got one of those as I have broken up a few Indesits. :tup: Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
