Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hpt WMA 10
- This topic has 10 replies, 8 voices, and was last updated 18 years, 7 months ago by
happycack.
August 18, 2007 at 12:42 pm #29878
happycack
ParticipantMachine does nothing except doorlock light flashes. Changed that but to no avail.
Any head start clues?August 18, 2007 at 12:59 pm #225034senseib
ParticipantRe: Hpt WMA 10
control Board will have blown – sometimes you can repair them others you cant!
Hope this helps,
Brian.August 18, 2007 at 1:01 pm #225035Penguin45
Dead door lock, or blown board.
How did you managed to change the door lock light? 😆
August 18, 2007 at 4:26 pm #225036johnnyj
The 1603557 board is prone to this fault and no sign off blown tracks, i’ve changed a good few after trying door lock.
August 18, 2007 at 5:49 pm #225037happycack
Thanks chaps, I’ll give her a quote monday.
(presuming you are all male, anyone know of a female domestic appliance engineer?)August 18, 2007 at 6:00 pm #225038iadom
ModeratorRe: Hpt WMA 10
happycack wrote:Thanks chaps, I’ll give her a quote monday.
(presuming you are all male, anyone know of a female domestic appliance engineer?)There is at least one forum member of the fairer sex. 😉 and I don’t mean Gegsy. 😆
August 18, 2007 at 6:34 pm #225039Penguin45
Mrs P can do a set of Hotpoint 95 bearings faster than I can…….
August 18, 2007 at 6:57 pm #225040Bryan
I’d make sure the motor and wiring tests all ok.
Don’t know if it’s just my luck but I often find a faulty motor blowing the module on Hotpoint WMA range.Bryan
August 19, 2007 at 10:37 am #225041electrofix
had one the other week with this fault found out if i held start button until door locked machine then worked ok have not heard from customer since
have not had one since to see whether this is a one off fixDave
August 19, 2007 at 9:52 pm #225042happycack
ParticipantThanks Dave, I’ll try that too. Can be a bit “suck it and see” this game sometimes.
August 25, 2007 at 12:34 am #225043atech
Have you checked the door pecker? I have had a number of door lock faults and the door catch has been loose. IE there is not enough pressure on the door peg, to activate the interlock.
