HPT WMA30
  • #18474
    DAR01
    Replaced tub rear on above today,
    When set on wash program starts to fill then stops after about 10 seconds and door lock releases, any ideas what the problem could be ?
    Checked all the wiring all seems Ok.
    Can the WMA boards be re programmed ?
    Mike 🙁 🙁 🙁
    #179161
    Re: HPT WMA30
    Had one doing this last week , needed a new board to cure. Boards can be repaired by QER or EMW but not reconfigured. Having said that a new board is only a tenner more.
    Worth trying the component test programme first though.
    #179162
    DAR01
    Re: HPT WMA30
    Thanks for the info, I’ve got a spare board will try that.
    Mike 😆 😆 😆
    #179163
    Re: HPT WMA30
    A strong possibilty as you have just replaced the drum is a dodgy contact somewhere.
    #179164
    Re: HPT WMA30
    check you have got the single wires the right way round does weird things if you swop them covered wire to right from front of machine
    DAR01
    Re: HPT WMA30
    Don’t usually disconnect wiring to the control board when removing the drum,could that be causing a problem?
    If not problem may be bottom end somwhere, haven’t been back yet to try the spare board.
    Mike 🙄 🙁 🙄
    #179166
    Re: HPT WMA30
    I always remove the whole console, and the metal backplate, only takes a couple of minutes and makes the drum removal much easier.
    #179167
    Re: HPT WMA30
    i agree with iadom
    taking the panel off makes it easier and less chance of water getting into it or getting knocked
    whitevanman
    Re: HPT WMA30
    i dont disconect the pcb, just the wires to then water valves (colour coded etc) also the wires to the mains filte,r swing pcb with wire to the right hand side- 40 mins tub changed and running max – decent kitchen etc
    #179169
    funkyboogy
    Re: HPT WMA30
    i wouldnt even go that far wayne….
    remove connectors from pcb…taking care to mark where connectors came from?
    unscrew top panel which house the pcb etc…unclip wires that run down right hand side to motor etc…snip of cable ties underneath tub…
    and then just hang top panel over left hand side of w/m…lift tub assy out > place doorseal side down >>remove connectors from motor/heater…
    this can all be done without fill hoses etc removed….
    saves a bit of time and not that complicated..although it does sound that way when your trying to write it down..
    ally
