Hpt WMF720 leak from draw Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hpt WMF720 leak from draw This topic has 6 replies, 3 voices, and was last updated 13 years, 2 months ago by allan73. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts January 19, 2013 at 4:21 pm #73640 allan73Participant Hi folks, the above leaks from the soap draw in the rinses. I’ve levelled the m/c and turned the water pressure down but she still leaks on the last rinse. Is this a known problem ? Allan. January 19, 2013 at 4:31 pm #388256 MartinParticipant Re: Hpt WMF720 leak from draw Sump hose ball valve blocked with crap? Or if it simply leaks whilst filling then replace dispenser top half. January 19, 2013 at 4:37 pm #388257 allan73Participant Re: Hpt WMF720 leak from draw Whilst filling Martin but only on last rinse. Will it need a dispenser top ? January 19, 2013 at 4:38 pm #388258 iadomModerator Re: Hpt WMF720 leak from draw A known fault, replace the complete, re designed dispenser assembly. 😉 January 19, 2013 at 4:42 pm #388259 allan73Participant Re: Hpt WMF720 leak from draw Thanks Iadom. Will do. January 19, 2013 at 4:50 pm #388260 iadomModerator Re: Hpt WMF720 leak from draw May have to order both parts separately for this model. C00283631 & & C00283632. Sent from my iPad using Tapatalk HD January 19, 2013 at 4:56 pm #388261 allan73Participant Re: Hpt WMF720 leak from draw Much apppreciated. Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
