Hi gents have a wma 62 lock not working or machine wont start need help on this one found poor insulation on motor 79,9 m ohms tried new motor but machine still not starting & new door lock
cheers alro
Thats assuming you have used your terminal screwdriver to slide across the door lock. This eliminates the door handle / hook / spring from being your culprit. They can sometimes look & feel ok!
thanks for reply i assumeb it could be but the chlid lock is not on can select any prog but the key hole flashes when start button pressed and bleebs 5 times no fault code apears or is this 5 bleeps a code
any more checks i can do would help me
cheers alro
The boards gone belly up then either caused by the motor or more likely the interlock. Check the board to see the circuit that’s to blame for its demise.
