Htp Aqualtis AQ9D69U
  • #76338
    speedqueen
    Hi, been to this machine after another engineer changed the door seal but now cant fix it apparently? Here’s the problem . . . .You can select the wash, but It wont start the wash, just drains continually, and the door lock is lit as soon as you power up the machine but the door wont open either. Dont want to force the door open. Is there a trick to getting it open without smashing the door latch ?
    any help anyone?
    cheers guys
    #398097
    madangler1
    Re: Htp Aqualtis AQ9D69U
    It thinks its full. Likely had a blocked pump and its been removed. Try the reset procedure of fill it with 2L of water and let it pump out.
    I have found quite a few of these get stuck and the only way I have found to reset them is to reprogram the EPROM.
    #398098
    speedqueen
    thanks. what is the reset procedure? Dont i have to reprogramme the EPROM via a laptop?
    #398099
    speedqueen
    ok, this machine is driving me crazy! Done the reset. which was a laff cos the door wouldnt open so had to remove the soap drawer lid lol. then it wouldnt fill, so pressed the start button with the door open, did it’s usual click click i’m not shut routine. said shut door, did that pressed start, (on rinse) worked fine, door opened. Set it again on coloureds 40 degrees starts, turns, but dosnt fill?? I hate being beaten but think this one has got me. Do i just concede to it being a board fault? what d’ya think?
