Htp wd64
  • #31196
    alfie
    Both high and low drying cycles seem to be to hot.
    Customer complains of hot steaming clothes when complete cycle finishes. One stat is 185c the other has red spot. They were both replaced approx 15 mths ago.
    Heaters are switching off about 12 mins before the end of cycle.
    Water is entering the condenser.
    Can any one help ❓
    #230226
    Re: Htp wd64
    Sounds like an inlet valve problem. An intermittent condenser valve solenoid failure would cause this. Might be worth trying a known good solenoid on the condenser inlet valve for a couple of washes. You will need to change the complete three way valve to effect a proper repair as the normal fill valve solenoids do not like being energised for hours.
    I have seen these valves fail after watching them for half an hour.
    I take it you have checked the condenser itself for blockages?
    alfie
    Re: Htp wd64
    Yes I took condenser off and cleaned it . Not much in there anyway. I will try the water valve
    Thanks Jim
    #230228
    roy1
    Re: Htp wd64
    Have you checked the filter, a part blocked filter will give you an increased amount of water in the tub.
